Unexpected reboot during silent install
SNHU_IT
We are deploying ABB RobotStudio 2022.2 via SCCM using PowerShell scripts. The script is needed for the activation of the network license, unless this has been corrected.
See:
RobotStudio Silent Install — ABB Robotics User Forums
During the installation if the machine has never had ABB installed it will reboot during the process even with
After a bit of installing the machine will reboot with System Event:
See:
write-host "Installing ABB RobotStudio..."
$PathRobotStudio = $psscriptroot + '\RobotStudio\setup.exe'
$ArgsRobotStudio = ' /S /v/qn'
start-process -wait -NoNewWindow $PathRobotStudio -argumentlist $ArgsRobotStudio
The process msiexec.exe has initiated the restart of computer DEPLOYSERVICES on behalf of user NT AUTHORITY\SYSTEM for the following reason: No title for this reason could be found
Reason Code: 0x80030002
Shutdown Type: restart
Comment: The Windows Installer initiated a system restart to complete or continue the configuration of 'ABB RobotStudio 2022.2'."
Activation in the same script:
$LicenseEXE = $ProgramFilesx86 + "\ABB\RobotStudio 2022\Bin\RobotStudio.Installer.exe"
$ArgsLicenseEXE = ' SetServer ourserver.contoso.com'
Any prerequisites perhaps triggering the reboot?
If i uninstall and reinstall using the same script the machine does not reboot. I will dig through the machine to see if I can find any logs to review, but if anyone has any suggestions i am all ears!
Thanks in advance.
Thanks in advance.
It was a prereq of MS Visual C++
On another note it seems you can place the key back into the install cmd.
Good luck out there1
