Export the work envelop
is it possible to export the work envelop as a CAD-Model? A simple STL/DXF would do the job.
If not, is it possible to access the mesh data via API?
thx
  • Marcus_
    Marcus_
    Answer ✓
    Hi Kater,
    In the Layout tab you can right click on the Mechanism --> Show Work Envelope. From there you can add it to station and where you, in the Layout tab, right click on the work envelope --> Export.
    Best Regards,
    Marcus
    ABB Robotics
  • Kater
    Kater
    edited August 2022
    Hi Marcus,
    at first I thought that was the solution, but the export function only exports the station, not the workspace.
      Best regards
       Torsten
  • Hi Marcus,
    i used RobotStudio 2021. Is the function available in 2022?
    Torsten
