Hello is there a way to set up a simple running light?
I want a green light to show the robot is running.
if the stop button is pressed or the door is opened the light goes of.
You can map and make a signal that will be a system output for program is executing. Have it turn on a relay which will power your light. You can read up on such things in the System parameter manual.Lee Justice0
Hey OP! I am curious to know how you solved this issue.0
Hi !For example by mapping it to controller CycleOn in config files:#
EIO_SIGNAL:-Name "do_GreenBeacon" -SignalType "DO" -Device "ABB_Scalable_IO"\
-DeviceMap "0"#
SYSSIG_OUT:-Name "do_GreenBeacon" -Status "CycleOn"
Fritz.
- 365 IRC5
- 84 OmniCore
