how to move macro from station to user
Klaus
To use a macro with event is have to be placed in "Station Add-ins" and if i want to use it in other stations it have to be in "User add-ins".
When i have moved it to station Add-in i cant move it back to user Add-in and use it in other stations.
Am i doing something wrong?
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus!
I think I know what you mean... the macro is saved in a project; then if you create a new station you can open the project again and when you debug it this macro will be included in the VSTA User Add-Ins and you will be able to load it in the new station.
Hope it helps!
Best Regards,
Anna
Best Regards,
Anna0 -
Sorry, even easier, no need to open the project, right button over the name of the project (it should be in VSTA User Add-Ins if you saved it) and Load Add-In...
Best Regards,
Anna
Best Regards,
Anna0
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
