I'm currently in the process of setting up an older system, and I have some troubles finding  the "CollisionErrorHandling" system parameter.
I have never set it up in a RW 5. But i know th
at in RW 6 and above, the system parameter is under: Configuration > Controller > General Rapid > CollisionErrorHandling:
RW5, the "General Rapid" is not in the tree.  How do I enable that system parameter then?
