TPReadNum in semistatic task RW 7.7
we are use comand TPRead in semistatic task but its not work, program pointer is on this line but i can not see something on flexpendant. It was work on some older RW now we have RW 7.7 (TPWrite is work)
Is there some another option what I have to set?
  • Try uinumentry
    If I helped, please press Vote Up  :smile:
  • This is a new bug in omnicore. We have the same problem. Stopped working with RW7.7. The new omnicore robots and controllers are nice but the software and new FlexPendant is still a disaster if you ask me.
    David
    Swedish freelance ABB robot programmer
  • seggan
    seggan
    edited October 2022
    So this is indeed a bug in the TPU. It looks like it is fixed in RW7.8, so please try to upgrade once it is available for download.
    Emil
  • Try uinumentry
    This function is better (many option) but its not works too :(
    Thank you for showing this function
    I have similar opinion on Omnicore but in newer version its better and better.
    seggan said:
    Emil
    Thank you we will try it.
  • I try it on RW 7.8 its works!
    Good to hear! :)
    Emil
