TPReadNum in semistatic task RW 7.7
jarmmi2
we are use comand TPRead in semistatic task but its not work, program pointer is on this line but i can not see something on flexpendant. It was work on some older RW now we have RW 7.7 (TPWrite is work)
Is there some another option what I have to set?
Try uinumentrySystemintegrator - Web / C# / Rapid / Robotstudio
This is a new bug in omnicore. We have the same problem. Stopped working with RW7.7. The new omnicore robots and controllers are nice but the software and new FlexPendant is still a disaster if you ask me.
David
Hello,So this is indeed a bug in the TPU. It looks like it is fixed in RW7.8, so please try to upgrade once it is available for download.Best regards,Emil1
Tompanhuhu said:Try uinumentry
Thank you for showing this functionNewman said:This is a new bug in omnicore. We have the same problem. Stopped working with RW7.7. The new omnicore robots and controllers are nice but the software and new FlexPendant is still a disaster if you ask me.seggan said:Hello,So this is indeed a bug in the TPU. It looks like it is fixed in RW7.8, so please try to upgrade once it is available for download.Best regards,Emil
Thank you we will try it.0 -
I try it on RW 7.8 its works!0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
