TPReadNum in semistatic task RW 7.7
jarmmi2
we are use comand TPRead in semistatic task but its not work, program pointer is on this line but i can not see something on flexpendant. It was work on some older RW now we have RW 7.7 (TPWrite is work)
Is there some another option what I have to set?
Try uinumentrySystemintegrator - Web / C# / Rapid / Robotstudio
This is a new bug in omnicore. We have the same problem. Stopped working with RW7.7. The new omnicore robots and controllers are nice but the software and new FlexPendant is still a disaster if you ask me.
David
Hello,So this is indeed a bug in the TPU. It looks like it is fixed in RW7.8, so please try to upgrade once it is available for download.Best regards,Emil1
This function is better (many option) but its not works tooTompanhuhu said:Try uinumentry
Thank you for showing this function
I have similar opinion on Omnicore but in newer version its better and better.Newman said:This is a new bug in omnicore. We have the same problem. Stopped working with RW7.7. The new omnicore robots and controllers are nice but the software and new FlexPendant is still a disaster if you ask me.seggan said:Hello,So this is indeed a bug in the TPU. It looks like it is fixed in RW7.8, so please try to upgrade once it is available for download.Best regards,Emil
Thank you we will try it.0 -
I try it on RW 7.8 its works!0
