[Request] Detailed Jogging View
It would be great to have a detailed Jogging View. Preferably on the right side. Something like this:
Or this:
            Hello Eric,
 Thanks for the suggestion.
 I will run this by R&D and get back to you.
  —Maxim RiabichevPC Software Support Engineer0 —Maxim RiabichevPC Software Support Engineer0
            Hello Eric,
 Could you elaborate on your request - what exactly is missing from what can be shown currently in RobotStudio?
 Thanks. —Maxim RiabichevPC Software Support Engineer0 —Maxim RiabichevPC Software Support Engineer0
            The whole bread and butter work is moving the robot and teaching positions. So I think it could be more convenient than how it is now.Here an example of the current process:There are 2 tools and 2 wobjs.To jog the robot, I have to right click on the robot in Layout (only in Layout) and hit mechanism joint jog or mechanism linear jog.To have both and therefore switch fast between them, I have to teardown both panels and arrange them properly each session.If I want to switch the tool now, I have to look at the bottom panel (which is only visible in home tab, so I have to switch to home tab). To make the robot use the tool, I have to switch to tool in the mechanism linear jog panel.Now I jog the robot to a proper position. After that the position has to be saved in an instruction.I have to make a path active, so I switch to paths&targets to make the right path active. Now I want to change instruction options (not jogging) from linear to joint as well as used tool and wobj (also only possible in home tab).To save the robot pose in a new instruction I hit teach instruction in the top panel.Next postion is better reached with a different tool. So back to bottom panel and switching the tool. Also it needs to be a fine position and speed should be v100. Now back to mechanism jog linear window and setting it properly. Ok the teached position doesn't need to be a fine point, so back to Paths&Targets then right click on instruction -> modify instruction -> etc.Here an example how the more convenient process could be:You switch to teaching tab and now you have all options on a side panel: Joint jogging, linear jogging, switching of active tool and wobj, switching of instruction options and selecting the active path, for creating a new instruction. Also changing of instruction options could be located there.So, this is more something for a faster and productive workflow. It is not about functionality itself.0
            Hello Eric,
 Sorry for the slow response.
 Thanks for the clear example.
 I ran this by R&D and they agreed that this sounds like a good idea.
 I have created a feature request for it, so now it's up to them to fit it into one of the iterations.
 I'll get back to you when I have more news.
 Thanks again! —Maxim RiabichevPC Software Support Engineer1 —Maxim RiabichevPC Software Support Engineer1
            That's why I like ABB. Finally someone who hears the customer.0 Finally someone who hears the customer.0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
