Where is the VC backup located when using Autosave in RS 2022?
I have RobotStudio 2022.2.1 and had a system failure on my VC.
My only hope to recover some background task is the Autosave fuction but I can't find any backup files in my project folders.
In options->AutoSave it looks like VC backup is enabled.
/David
David
Swedish freelance ABB robot programmer
  • Maxim Riabichev
    edited November 2022 Answer ✓
    Hello Newman,
    So I did some digging and these are my findings (in RobotStudio 2022.3):
    • RAPID code is backed up to "%localappdata%\Temp\RobotStudio\"
      It only saves the un-applied changes made in the editor. As soon as you hit Apply, the "backup" is removed.
    • The autosave of the station and station files does not work. (It looks like it does, but it doesn't.)
    • Automatic backup of controllers does not work.
    • If you manually save the project, a backup of the controller is made and placed in "...\RobotStudio\Projects\Project1\Controller Data"
    I will speak to R&D regarding these issues with autosave.
    Maxim Riabichev
    PC Software Support Engineer
  • Also when station is saved by me, I can see that RS is doing controller backup. But I can't find the backup in any folder.
    Not in "...\RobotStudio\Backups"
    Not in "...\RobotStudio\Projects\Project1\Virtual Controllers\BACKUP"
    Does anyone know?
    David
  • Seems like the controller backup stopped working when RS went from Solutions to Projects.
    In an old RS solution I can find the controller backup in "...\RobotStudio\Solutions\Solution 1\Backups"
    David
  • Thanks! I found the backups from save project in the "Controller Data" folder as you said.
    Let's hope that autosave will be fixed too.
    /David
    David
  • David, are you saying that the backups of VC's work? Do you have multiple version of your VC in Controller Data?
    Maxim Riabichev
  • No, only one backups folder per robot controller.
    I have three robot controllers in my current project so therefore three folders.
    David
  • Alright, thanks.
    Maxim Riabichev
