Where is the VC backup located when using Autosave in RS 2022?
Newman
I have RobotStudio 2022.2.1 and had a system failure on my VC.
My only hope to recover some background task is the Autosave fuction but I can't find any backup files in my project folders.
In options->AutoSave it looks like VC backup is enabled.
/David
/David
David
Swedish freelance ABB robot programmer
David
Hello Newman,
So I did some digging and these are my findings (in RobotStudio 2022.3):- RAPID code is backed up to "%localappdata%\Temp\RobotStudio\"
It only saves the un-applied changes made in the editor. As soon as you hit Apply, the "backup" is removed.
- The autosave of the station and station files does not work. (It looks like it does, but it doesn't.)
- Automatic backup of controllers does not work.
- If you manually save the project, a backup of the controller is made and placed in "...\RobotStudio\Projects\Project1\Controller Data"
I will speak to R&D regarding these issues with autosave.Post edited by Maxim Riabichev on
—Maxim RiabichevPC Software Support Engineer0 - RAPID code is backed up to "%localappdata%\Temp\RobotStudio\"
Also when station is saved by me, I can see that RS is doing controller backup. But I can't find the backup in any folder.
Not in "...\RobotStudio\Backups"
Not in "...\RobotStudio\Projects\Project1\Virtual Controllers\BACKUP"
Does anyone know?-----------------
David
Seems like the controller backup stopped working when RS went from Solutions to Projects.
In an old RS solution I can find the controller backup in "...\RobotStudio\Solutions\Solution 1\Backups"-----------------
David
Thanks! I found the backups from save project in the "Controller Data" folder as you said.
Let's hope that autosave will be fixed too.
/David-----------------
David
David, are you saying that the backups of VC's work? Do you have multiple version of your VC in Controller Data?
No, only one backups folder per robot controller.
I have three robot controllers in my current project so therefore three folders.-----------------
David
Alright, thanks.
