Integrate the 2 IRB-1300 robots to be able to use multi-tasking commands
Hello
I am working on the design of an assembly solution with 2 robots in the same working cell in the Robotstudio. I choose the IRB 1300 with a 10 kg workload capacity. I want to integrate the 2 robots into one controller to be able to use the multi-tasking command  (WaitSyncTask, SyncMoveOn, SyncMoveOff) but seems like the version of the IRB-1300's controller is not support this function. Does anyone have a solution to integrate the 2 IRB-1300 robots to be able to use multi-tasking commands? Please suggest. Thank you.
  • You must have the option multimove coordinated, it should not be controller specific, but specific to what you purchased.
    Lee Justice
  • 1300 robot is an omnicore generation robot.
    Omnicore dosen't support multimove (yet) so only one robot per controller is supported.
    If I helped, please press Vote Up  :smile:
    Thank you for your information. Do you know when will the support version is available in the Robotstudio? or where can I check about this?
  • graemepaulin
    graemepaulin ✭✭✭
    edited August 2022
    MultiMove for the Omnicore is in the rollout plan - not sure of the timing.
    You can sync the two robots using IO and careful programing...
  • How about setting up one omnicore as an Ethernet/IP slave to the other?  What would the device configuration be?
