FTP Server on omnicore RW 7?
Tompanhuhu
in OmniCore
Is it possible to connect to robotcontroller with ftp?
If I helped, please press Vote Up0 -
I have not attempted to connect to an OmniCore via FTP myself.
Have you consulted the manual(s)?—Maxim RiabichevPC Software Support Engineer0 -
I have read multiple manuals trying to find any info about the topic but all I can find is references to the option sftp client. Nothing about the server.Systemintegrator - Web / C# / Rapid / Robotstudio
Based on the information in "3HAC066554 AM Controller software OmniCore-en.pdf" Chapter 7.1 there is no FTP server in the controller. Instead, you have to host an FTP server elsewhere and configure the FTP Client in the controller to access it.—Maxim RiabichevPC Software Support Engineer1
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
