3Dconnexion mouse to move the robot
Hi all,
Is it possible to use a 3Dconnexion mouse to move the robot, similar to how the FlexPendant joystick operates?
Any research online only shows a manual of an add-in (poly-robotics) but I am unable to find the add-in anywhere.
Any help is greatly appreciated.
Thanks,
Greg
Thanks,
Greg
There was an addin for this, but it's no longer available.
Wasn't that addin only for jogging axis by axis, i.e. no reorient or linear jog?-----------------
David
Swedish freelance ABB robot programmer1 -
afaik, this is correct.Newman said:Wasn't that addin only for jogging axis by axis, i.e. no reorient or linear jog?Systemintegrator - Web / C# / Rapid / Robotstudio
@Newman
@Tompanhuhu
Thank you both for your feedback
Thats unfortunate, it seems like it would be a great feature to be more efficient when programming offline.
If you move the robot to teach targets in the 3D environment, I think you can work more effectively
☑️2024 - RobotStudio® User Group0
