3Dconnexion mouse to move the robot
Hi all,
Is it possible to use a 3Dconnexion mouse to move the robot, similar to how the FlexPendant joystick operates?
Any research online only shows a manual of an add-in (poly-robotics) but I am unable to find the add-in anywhere.
Any help is greatly appreciated.
Thanks,
Greg
  • There was an addin for this, but it's no longer available.
    If I helped, please press Vote Up  :smile:
  • Wasn't that addin only for jogging axis by axis, i.e. no reorient or linear jog?
    David
    Swedish freelance ABB robot programmer
    afaik, this is correct.
  • @Newman
    @Tompanhuhu
    Thank you both for your feedback :smile:
    Thats unfortunate, it seems like it would be a great feature to be more efficient when programming offline.
  • If you move the robot to teach targets in the 3D environment, I think you can work more effectively :wink:
