Install Robotstudio, wrong windows version
ChristianJ_PKS
edited January 2023 in RobotStudio
I'm trying to install Robotstudio 2022.3.1 but it fails on wrong windows version.
What am I doing wrong?
link to screenshot
  • Maxim Riabichev
    edited January 2023
    This installation issue occurs when there's an issue with your windows installation.
    If you perform this command: "get-wmiobject win32_operatingsystem" in PowerShell and its output is empty, then the installer will fail.
    The recommendation is to reinstall your OS.
    Maxim Riabichev
    PC Software Support Engineer
  • Hi,
    Thanks for your support.
    Yes it was a issue with WMI services.
    I did run following commands to solve the problem
    CMD as administrator
    dism /online /cleanup-image /checkhealth
    SFC /scannow
    CD C:\>windows\system32\wbem
    regsvr32 /s %systemroot%\system32\scecli.dll
    regsvr32 /s %systemroot%\system32\userenv.dll
    regsvr32 cimwin32.dll
    mofcomp cimwin32.mof
    mofcomp cimwin32.mfl
    mofcomp rsop.mof
    mofcomp rsop.mfl
    for /f %s in ('dir /b /s *.dll') do regsvr32 /s %s
    for /f %s in ('dir /b *.mof') do mofcomp %s
    for /f %s in ('dir /b *.mfl') do mofcomp %s
    regsvr32 wmisvc.dll
    wmiprvse /regserver
    regards
    Christian
  • Hi Christian,
    Thank you for providing that information!
    Maxim Riabichev
  • Maxim Riabichev
    edited September 2023
    For future reference.
    There is a workaround to install RobotStudio, ignoring this error.
    Run the command (from the folder where setup.exe is located):
    setup.exe /s /v” /qb ADDLOCAL=ALL OSCHECKOK=1"
    Maxim Riabichev
