Video Capture
I was curious, is there any way to capture video of a simulation in robot studio 5.08?
dh_custompak2010-05-30 04:29:21
Dustin
  • Hi
    I use a software called Camtasia to record a simulation.
    Per Svensson
    Consat Engineering
  • Hi Dustin,
    Video capture will be available in 5.09. I'm looking into creating an addin for 5.08, just wait an hour or so :)
    Johannes Weiman
    ABB Robotics
  • Thats awesome! Thanks guys for the help image
    Thanks Again,
    dh_custompak2010-05-30 04:45:22
    Dustin
  • Try this (instructions included):
    2007-03-21_164233_VideoCapture.zip
    This is pretty much the same code that will be included in 5.09, so any feedback is appreciated :)
    regards,
    Johannes
    Johannes Weiman
    ABB Robotics
  • Thank you so much for the support, I am extremely excited to try this out!image
    Thanks Again,
    dh_custompak2010-05-30 04:45:33
    Dustin
  • I love it, keep up the good work! The only thing I see, and you might not be able to control but the color is off in some parts of the video and its a little laggy. The only other thing is I noticed it doesnt want to work on my dual displayimage so right now it seems like when I use it I have to turn off my dual display. But again I just want to thank you a lot I love this add-on and would reccomend it to everyone who uses Robot Studio!
    Thanks Again,
    dh_custompak2010-05-30 04:45:42
    Dustin
  • Hi Dustin,
    This update should fix the dual display issue:
    2007-03-22_131931_VideoCapture.zip
    I haven't found a way to increase the color fidelity. But you should disable gradient background in the graphics to get rid of the worst color banding.
    regards,
    Johannes
    Johannes Weiman
    ABB Robotics
  • Awesome, that takes care of the worst problem that I was having.
    Thanks Again,
    dh_custompak2010-05-30 04:45:12
    Dustin
  • Klaus
    Klaus ✭✭
    I have tried the add-in but the toolbar is grayd so i cant use it.
    What do i do wrong
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • Hi
    Read the info in the text file, need to install Windows Media Encoder 9
    Per Svensson
    Consat Engineering
