Virtual Controller Startup Issue - non-admin account
XNOR
I’m having trouble getting RobotStudio to run virtual
controllers for non-admin accounts. Has anyone else encountered this issue? Running as an admin seems to correct but isn't a solution for users with non-admin accounts.
Starting a virtual controller will yield the following popups:
"RobVC::Launch: vcrunLoadSystem failed to load dll, e.g. unresolved symbols."
and
This popup duplicated in the output pane:
4/18/2022 4:10:58 PM
There was a problem when starting the virtual controller
The release directory
C:\Users\[username]\AppData\Local\ABB\RobotWare\RobotWare_6.05.2005
is missing or corrupt, and cannot be used when launching a VC.
Update 2/2/23-solution below
Post edited by XNOR on
1
Update - we finally got a solution working with our ABB support and our IT security team. Our security software was preventing the virtual controllers .dll from running. IT was able to watch a log of what was blocked when we tried starting a VC. You can also reference the .dlls being launched from the log RobotStudio can generate (File>Help>Support Tool>Fault Log Files Tab). NOTE - our system had to have a whitelist rule with a wildcard as each version of robotware is running from a different pathname.
Good luck0
Hello.
It seems that i have same problem.
Does anybody know how to solve these problems?0 -
I have been in touch with my local ABB, and have sended XNOR´s solution to them to solve if we have same issue going on.
Hopefully we have same issue with security softaware 🤞0 -
ABB can't do anything about your security software -- You've got to get your IT team to create the exception.0
