Virtual Teach pendant and Screenmaker "Failed to Initialize"
I'm running the most recent version of robotstudio, and am trying to set up an on-pendant HMI using screenmaker.   I am connected to a live robot ( one-click connect ) and when I create any screenmaker HMI and build/deploy it, I get the error message saying it cannot find part of the path.
When I am connected to a virtual controller and use ScreenMaker, I have no problems... only a live robot.    Even a blank mainscreen causes this error on my RobotStudio with the live robot.
------snip8<----------------
Failed to initialize Virtual Flexpendant
System.IO.DirectoryNotFoundException:  Could not find part of the path'C:hd0a\threebears\PRODUCTS\RobotWare_6.13.4007\vcbin'.  at System.IO._Error.WiniOError(Int32 ErrorCode, String maybe FullPath)   etc
  • The solution was that you can't use the virtual flexpendant on a real system ( only a virtual system ).   It would be nice if a dialog box popped open saying that rather than a cryptic error message.
