RobotWare CD 5.08
joaof
I recive a IRC5 controler whith a 140 Robot, ABB send the robot the controler but don't send de CD's whith RobotWare 5.08 I can't connect to controler whith my RobotStudio Online to program by PC.
Were I can found the robotWare 5.08???
Joao Fidalgo
Contact your local ABB support office.Russell Drown0
Be aware of that when you order a new Robot there is an option if you want the RobotWare boot package.
Maybe that's why you can't find it.Per Svensson
Consat Engineering0 -
The problem is solved, I contact the tecnical Suport and they give me a copy of a CD with RoboStudio Online 5.08 in 24hours. If the robot have a robotware version grather then RoboStudio Online you can see the controler but he is lock in robostudio online!0
