[Wish] RS Format Document & Adjust Case Like Real Controller
DenisFR
DenisFR ✭✭✭
When using Format Document or Adjust Case in RobotStudio, it makes a lot of change if you edit your program on real controller before.
Real:
RS:
Real:
RS:
  • Added to backlog!
    Johannes Weiman
    RobotStudio Team, ABB Robotics
  • — BUMP —
    Maxim -
    Is there an update that may be shared on this request?
    It would be extra specially nice if RS had an option for using RS formatting or control formatting.
  • Hello SomeTekk,
    I see you went and did some digging?
    Can you provide a clear description (with screenshots where possible) of how things are today vs. how things should be in a not-so-distant utopian future?
    Then I'll run it by R&D.
    Maxim Riabichev
    PC Software Support Engineer
  • I would if I was able to paste screenshots in the message box, unfortunately the only option available is to link an image.
    For the most part DenisFR captured the essence of what I am hoping for with the first post.
    Whitespaces are prepended to the arguments in (some/all?) instructions when composed on the controller. Whitespaces are deleted when Format Document is clicked and eventually updated on the controller.
    A "controller entry mode" would be nice where RS uses the entry syntax present in the controller. Perhaps in the Format drop down a selection for control style syntax emulation formatting could be used. I am am a heavy user of Format in RS and in this facility there are a number of techs that gripe about differences, being able to format like the controller might quell the griping — slightly.
    Hope this helps.
  • Maxim Riabichev
    edited March 2023
    I fail to see why there would be a need for a different formatting in RS compared to the controller? Wouldn't it be better if RS followed the same formatting as the controller?
    Maxim Riabichev
  • Yes. If only one format can exist, then RS formatting as the controller creates its format would be sufficient.
  • Alright, I'll see what I can do.
    Maxim Riabichev
  • Hello there,
    R&D has decided to focus on other more issues issues and thus will not adjust the formatting of RAPID code in RobotStudio (basically it's a question of allocating limited resources to issues with higher priority).
    Maxim Riabichev
