Preventing system module deletion
suffq
Hi there,
I was wondering if anyone could help me with preventing system modules from being seen and/ or deleted.
I've looked into using the User Authorization System to create users with select permissions to stop system modules being deleted exclusively but I can seem to find the correct as I still need the ability to load program modules.
I've also looked into using the NOVIEW/ READONLY parameter but this only seems to limit viewing and doesn't seem to stop deletion.
Can anyone suggest a potential work around for this? There's been multiple instances of operators deleting system files accidently while trying to delete program files. Any type of prevention method would be greatly appreciated
Regards,
Quinton
Regards,
Quinton
Lee Justice1
how do I hide the BASE system module? I can seem to find/ create the correct pathing for this0
What version of robotware are you using?Lee Justice0
6.10.020
I've found the correct pathing the the BASE.sys. it's RELEASE:/system/BASE.sys0
- 341 IRC5
- 67 OmniCore
- 839 RAPID Programming
- 18 AppStudio
