IRC 1200 inverted robot
Hi everyone.
Currently i'm programming an ABB robot but it is inverted.
Do i need to modify some parameters for this position?
Hallo, you have to put parameter gravity alpha/beta to tell the controller that gravity now works in diffferent direction. See "system parameters".Also you should change your base orientation to have the right relation to world.0
Hi Matti, thanks for your support. That worked, thanks!!0
