Invalid data for component rot!
ARSIA
I often record points with the correct tool, coordinate system selected. But when I want manually adjust a point, and attempt to edit the data, I will get [MyPointName] Invalid data for component rot.
I suspect this has something to do with the rotation of my tool when the work object was created, but I am stuck as to what to look for.
Quaternions must be normalized. The sum of the components' square roots must equal 1. Or be very, very near it. There is a function to Normalize a rotation. If you are not too totally out of whack, it may help you.Lee Justice0
I will look into the function, just wondering when I teach / modify a point why it doesn't record the correct values in the first place.0
Hello,I've made a little software to help you with orientation:Look at Reorientation Tab.
Hi, I have the same issue with a great difference that the target has a rotation [1,0,0,0], thus perfectly normalized but I still get the error message when I hit the OK button in Program data edit window - invalid data for component rot. Does anybody experience the same issue?
RobotWare 6.15.01
Edit: I just tried an empty robot, added one robtarget with [1,0,0,0] orientation and still I can't edit the target using the Program data editor.0 -
We also got this issue/bug on RobotWare 6.15.01
After updating to 6.15.02 the issue was solved
- 365 IRC5
