Connect and write serial strings to Arduino device
Kappa95
Dear community,
I want to connect my Arduino with the IRC5 controller to send serial commands with strings. Is it possible to use the USB ports (X10-X11)?
Hallo, I had to look what an Arduino is about ...To use USB X10/11 your device must have some sort of IP with DHCP.I don not know if this is possible.But you have I/O-pins that works like I/O at a PLC.So might send your strings one after each other by binary coding 8 bits (inputs).0100 0000 = "@" (ASCII 256)0
Hence, in the end is needed to have a device with TCP/IP communication
Hallo,I/O's from PLC are usually connected by bus to the controller. But if you manage to connect your I/O pins with the I/O board of the controller directly, you might go a.m. way.0
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 33 AppStudio
