SmartComponent - Events for triggering a signal
I'm quite new in programming and I just started with the development of SmartComponents.
I would like to check the position of a joint value. If it has reached a defined position, the SmartComponent should trigger a DigitalOutput (=limit switch).
My problem now is, how can I connect the joint value with a DynamicProperty? If this is possible, I could use the event "OnPropertyValueChanged" to trigger further methodes.
thanks, Henry
