Unable to activate server license
Unable to activate server license with the 'Activation Wizard'. I typed in the host name for the license server and restarted robotstudio. I'm running the program as an administrator so there should be no problem, and it says "Server is online" next to it after applying. However, under 'View installed licenses..." nothing shows up. Other colleagues have tried the same without any issues. What could the problem be?
Hello,Can you open the server dashboard?☑️2024 - RobotStudio® User Group0
No I can't. " ERR_EMPTY_RESPONSE "DenisFR said:Hello,Can you open the server dashboard?0 -
Test by pinging it by its name then its IP.☑️2024 - RobotStudio® User Group0
Please make sure that all relevant ports are open.
You can refer to the RobotStudio manual -> network licensing.
Failed to ping it by it's name but succeeded with the IP-adress. I have tried to activate the server license using the IP-adress but that didn't work either.DenisFR said:Test by pinging it by its name then its IP.0 -
Are you referring to the firewall configuration?Maxim Riabichev said:Hello,
You can refer to the RobotStudio manual -> network licensing.0 -
Yeah."It requires two open TCP ports, by default 2468 (for the web interface) and 8731 (for licensing). The installer opens these ports in the standard Windows Firewall, but any third-party firewall must beconfigured manually by the system administrator."
Sollution:Maxim Riabichev said:Yeah."It requires two open TCP ports, by default 2468 (for the web interface) and 8731 (for licensing). The installer opens these ports in the standard Windows Firewall, but any third-party firewall must beconfigured manually by the system administrator."
I was running Robotstudio with version 6.02. Got a tip from a colleague to install a newer version, so I installed RobotStudio 2022/2023 and it worked with both.0
- 364 IRC5
- 82 OmniCore
