Virtual Flexpendant Ommicore does not run.
Hello,On Release Notes, you can find this:
Required Software
Microsoft Windows 10 Anniversary Edition or later, 64-bit edition, is required.
The Windows App Installer is a pre-requisite for the virtual OmniCore FlexPendant software, see https://www.microsoft.com/en-us/p/app-installer/9nblggh4nns1. The App Installer is a default built-in app in Windows 10 and later, but may have been removed on some PCs.
Sideloading of apps must be enabled on Windows to install the virtual OmniCore FlexPendant.
To enable sideloading follow these steps:
- Open Settings.
- Click Update & Security (Windows 10) or Privacy & security (Windows 11) > For developers.
- Ensure Developer Mode is set to On.
Thank you very much for your advice, but it doesn't work. I'm desperate.
Can you check that ABB Robotics FlexPendant application is associated with:.bash, .c, .cpp, .cs, .h, .hex, .hpp, .json, .jsp, .mot, .pgf, .ps, .py, .rlf, .rmf, .rpk, .rsf, .tarURL:flexpendant,☑️2024 - RobotStudio® User Group0
I solved the issue. I uninstaled ABB Robotics FlexPendant on windows and and reinstalled it again.
J.C.M.Castillo said:I solved the issue. I uninstaled ABB Robotics FlexPendant on windows and and reinstalled it again.hello, i have the same problem, could you tell me what you did?in the uninstall programs, i only see robotstudio and not ABB Robotics FlexPendant.
https://i.postimg.cc/Hk3YJkpJ/Cattura.png
Thank you0 -
hello, i have the same problem, could you tell me what you did?in uninstall programs, i only see robotstudio and not ABB Robotics FlexPendant. Thank you0
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
