Loaded program [WebWare SDK]
The only time this works is if you have loaded a module using the S4LoadModule method to load a program, otherwise the property does not get set. A workaround is to write the name of the module to a PERS RAPID variable when you access a module (or routine if necessary) and monitor that value. For example,
PERS string modName;
PERS string routName;
modName:="module1";
routName:="routine1";
For IRC5, there is much more capability in this area using Robot Application Builder.
Russell Drown0
- 303 PowerPacs
- 353 IRC5
- 850 RAPID Programming
- 25 AppStudio
