Test running program from FlexPendant
I have an active program loaded into RS5.07 that I am trying to test run using the Virtual Flex Pendant without any success. The problem is that when I try move the program pointer to the routine that I am trying to run, if I step through the routine, when I try to run a Move instruction, I get error messages stating that the client may not be in control and that required mastership could not be granted.
error message number: 20051
Could anyone explain what exactly is going on here and how to correct it?
Thanks,
Brian
Hi Brian,
Unfortunately can this sometimes happen in RS 5.07. Normally will a warmstart of the VirtualController solve it.
We are working on this problem for future releases.
I have been getting this problem with RS5.08 and warmstarts do not fix.
Has anyone found what is causing it?
"Argon Technology - your industrial robotics and automation partner, helping you build your tomorrow"0 -
I am also getting this problm in 5.08.
I can not run the program from the Flexpendant and get Client not in controll errors. Write Access has not been resquested in RSO and I am not testing reachability in the station.
This is very very very annoying !
I need an explanation what to do next!
- 398 UpFeed
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 327 IRC5
- 65 OmniCore
- 820 RAPID Programming
- 8 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
