How do I align target orientation?
I am using a saw blade to cut runners off aluminum castings, i need to adj. my end cut position. i need to align the two targets so the blade will track straight in the cut. i could rotate the start position then copy orientation and position then re offset the end cut position. i was hoping for something quicker and easier.
thank you
JD
thank you
JD
Hello,Why don't you use directly Offs function? So only one taught point is necessary.☑️2024 - RobotStudio® User Group1
Thank you for the reply, I hadn't thought of that. I'm new to programing, and I'm learning as I go.0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
