UIMsgBox without acknowledge
Hi guys,
i am trying to implement a UIMsgBox in a Backgroundtask which should pop up while a signal condition is given.
If the condition is given the robot is waiting for acknowledge the UIMsgBox. is there a way to erase this?
  PROC main()
    VAR String DreiCon_Logo:="/hd0a/3con.png";
    WHILE do_0058_3CS_Rob_in_Main=1 DO
      UIMsgBox
          \Header:="3CON",
            \MsgLine2:="  !        !"
            \MsgLine3:="  !                          ROBOT IS IN MAIN                          !"
            \MsgLine4:="  !        !"
            \MsgLine5:="  ! - - - - - - - - - - - - - - - - - - - - - - - - - - - - !"
            \Buttons:=btnNone
            \Icon:=iconInfo
            \image:=DreiCon_Logo
    ENDWHILE
    TPErase;
    WaitTime 0.2;
Robotic Software Engineer
  • lemster68
    lemster68 ✭✭✭
    Add the optional argument DiBreak.  If the message does not go away you might try TPShow TPLatest.
    Lee Justice
  • Hi Lemster, Thx for your feedback!
    I already got it fixed with an "UIMsgWrite"
    https://imgur.com/a/Z1YxECn
    Code is working fine.
    Just got the problem that i was not able to get a String into a String.
    So i swap the MsgArray instead.
    Maybe Someone also wanna make this :smile:
      PROC MSG_Display()
        ! > Setting boolean variable TRUE
        VAR bool b_Display:=FALSE;
        ! > Variables for MSG Box
        VAR string Message_Array{5}:=["","","","",""];
        ! > Variables depending on current execution
        !   > JOB 01-10
        VAR string Job_00_MAIN{5}:=[
          " !                   ROBOT IS IN MAIN                  !",
        b_Display:=TRUE;
        ! > Displaying a Infobox if robot is in main
        WHILE (do_0058_3CS_Rob_in_Main=1 XOR gi_0257_Job_Nbr_Start>0) DO
          ! > Array to write other message on executing job
          TEST GInput(gi_0257_Job_Nbr_Start)
          CASE 0:
            Message_Array:=Job_00_MAIN;
          CASE 1:
            Message_Array:=Job_01_Home;
          ENDTEST
          IF b_Display=TRUE THEN
            UIMsgWrite "Company Name",Message_Array\Icon:=iconInfo;
          ENDIF
          b_Display:=FALSE;
          WaitTime 0.2;
        ENDWHILE
        ! > Setting boolean variable FALSE
        b_Display:=FALSE;
        UIMsgWriteAbort;
        WaitTime 0.2;
