UIMsgBox without acknowledge
Braap
Hi guys,
i am trying to implement a UIMsgBox in a Backgroundtask which should pop up while a signal condition is given.
If the condition is given the robot is waiting for acknowledge the UIMsgBox. is there a way to erase this?
PROC main()
VAR String DreiCon_Logo:="/hd0a/3con.png";
WHILE do_0058_3CS_Rob_in_Main=1 DO
UIMsgBox
\Header:="3CON",
\MsgLine2:=" ! !"
\MsgLine3:=" ! ROBOT IS IN MAIN !"
\MsgLine4:=" ! !"
\MsgLine5:=" ! - - - - - - - - - - - - - - - - - - - - - - - - - - - - !"
\Buttons:=btnNone
\Icon:=iconInfo
\image:=DreiCon_Logo
ENDWHILE
TPErase;
WaitTime 0.2;
Robotic Software Engineer
Add the optional argument DiBreak. If the message does not go away you might try TPShow TPLatest.Lee Justice0
Hi Lemster, Thx for your feedback!
I already got it fixed with an "UIMsgWrite"
https://imgur.com/a/Z1YxECn
Code is working fine.
Just got the problem that i was not able to get a String into a String.
So i swap the MsgArray instead.
Maybe Someone also wanna make this
PROC MSG_Display()! > Setting boolean variable TRUEVAR bool b_Display:=FALSE;! > Variables for MSG BoxVAR string Message_Array{5}:=["","","","",""];! - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - !! > Variables depending on current execution! > JOB 01-10VAR string Job_00_MAIN{5}:=[" ! - - - - - - - - - - - - - - - - - - - - - - - - - - !"," ! !"," ! ROBOT IS IN MAIN !"," ! !"," ! - - - - - - - - - - - - - - - - - - - - - - - - - - !"];! > Setting boolean variable TRUEb_Display:=TRUE;! > Displaying a Infobox if robot is in mainWHILE (do_0058_3CS_Rob_in_Main=1 XOR gi_0257_Job_Nbr_Start>0) DO! > Array to write other message on executing jobTEST GInput(gi_0257_Job_Nbr_Start)CASE 0:Message_Array:=Job_00_MAIN;CASE 1:Message_Array:=Job_01_Home;ENDTESTIF b_Display=TRUE THENUIMsgWrite "Company Name",Message_Array\Icon:=iconInfo;ENDIFb_Display:=FALSE;WaitTime 0.2;ENDWHILE! > Setting boolean variable FALSEb_Display:=FALSE;UIMsgWriteAbort;WaitTime 0.2;ENDPROC
Robotic Software Engineer0
