[OpcUaClient Fixed in 2025.4] Doesn't work with Anybus
DenisFR
We test the OpcUaClient to connect a simulated B&R PLC with a virtual controller.
We see that using "841-1 EtherNet/IP Scanner/Adapter" works fine but using "840-1 EtherNet/IP Anybus Adapter" failed with error:
Bad result writing OPC UA data for node ::AsGlobalPV:RobotOutputs (status: 2155085824).
Device received the good data (input) but can't send them to PLC (output).
Does anybody have this error too?
☑️2024 - RobotStudio® User Group
Post edited by DenisFR on
UP
UP
UP
Denis, please reach out to your local ABB with this issue and report it as a potential bug.
Thanks.
Post update for RS 2023.4.1:Test creating an EthernetIP_Anybus with 128I/128O:And an EthernetIP with 128I/128O too:I've start OPC UA Client Configuration and add Controller Device I/O mapping:With EthernetIP it works fine:☑️2024 - RobotStudio® User Group0
Still here in 2024.1
Still presents in 2024.2.1
Still present in 2025.2☑️2024 - RobotStudio® User Group0
Hi Denis,
Did you report this via Local ABB?
Hello,Yes☑️2024 - RobotStudio® User Group0
@DenisFR can you PM me the case number/work item number please?
Still present in 2025.3☑️2024 - RobotStudio® User Group0
Fixed in 2025.4Still have bug when writing:Bad result writing OPC UA data for node ::AsGlobalPV:gRobotList[1].MapIn (status: 2155085824).Works fine with UaExpert.
BadTypeMismatch 0x80740000 2155085824 The value supplied for the attribute is not of the same type as the attribute's value
@DenisFR I'm glad to hear that the initial bug was fixed in 25.4
For the new one, please report it via Local ABB.
Thanks!
- 367 IRC5
- 858 RAPID Programming
