[OpcUaClient] Doesn't work with Anybus
DenisFR
We test the OpcUaClient to connect a simulated B&R PLC with a virtual controller.
We see that using "841-1 EtherNet/IP Scanner/Adapter" works fine but using "840-1 EtherNet/IP Anybus Adapter" failed with error:
Bad result writing OPC UA data for node ::AsGlobalPV:RobotOutputs (status: 2155085824).
Device received the good data (input) but can't send them to PLC (output).
Does anybody have this error too?
UP
UP
UP
Denis, please reach out to your local ABB with this issue and report it as a potential bug.
Thanks.—Maxim RiabichevPC Software Support Engineer0 -
Post update for RS 2023.4.1:Test creating an EthernetIP_Anybus with 128I/128O:And an EthernetIP with 128I/128O too:I've start OPC UA Client Configuration and add Controller Device I/O mapping:With EthernetIP it works fine:0
Still here in 2024.1
- 5.4K RobotStudio
- 381 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 247 ScreenMaker
- 2.7K Robot Controller
- 280 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 738 RAPID Programming
- 16 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
