Lake of Internal Event Objects
in IRC5
Hello All,
I am getting this error on our IRC5 IRB 6700 robot
what could cause the issue?
You need to increase the even objects in the motion planner. Default is 100, but you can set it for up to 500.
For some reason I am having trouble sharing photos... https://photos.app.goo.gl/En7UDSN7tKSVnD8P7
But it is under Motion--> Motion Planner --> Number of internal event objects
But what is the cause of this error? I have it on a robot that makes linear movements during gluing. Increasing to 500 didn't help. Any other ideas?
Hallo, do you use any TriggL or TriggJIOs or similar instructions?
