ModPos on a Move with RelTool or Offs
mechman
mechman
edited January 2016 in RobotStudio
Is there a way to modify a position and automatically subtract the offsets?  I have a program that always uses RelTool, so I am not able to use the "Modify Position" command to touch up the point.  Other than manually subtracting the current X&Y positions from the offsets, is there another way?
