[OpcUaClient] Doesn't work with Anybus
DenisFR
We test the OpcUaClient to connect a simulated B&R PLC with a virtual controller.
We see that using "841-1 EtherNet/IP Scanner/Adapter" works fine but using "840-1 EtherNet/IP Anybus Adapter" failed with error:
Bad result writing OPC UA data for node ::AsGlobalPV:RobotOutputs (status: 2155085824).
Device received the good data (input) but can't send them to PLC (output).
Does anybody have this error too?
☑️2024 - RobotStudio® User Group
UP
UP
UP
Denis, please reach out to your local ABB with this issue and report it as a potential bug.
Thanks.—Maxim RiabichevPC Software Support Engineer0 -
Post update for RS 2023.4.1:Test creating an EthernetIP_Anybus with 128I/128O:And an EthernetIP with 128I/128O too:I've start OPC UA Client Configuration and add Controller Device I/O mapping:With EthernetIP it works fine:☑️2024 - RobotStudio® User Group0
Still here in 2024.1
Still presents in 2024.2.1
Still present in 2025.2☑️2024 - RobotStudio® User Group0
Hi Denis,
Did you report this via Local ABB?—Maxim RiabichevPC Software Support Engineer0 -
Hello,Yes☑️2024 - RobotStudio® User Group0
@DenisFR can you PM me the case number/work item number please?
Still present in 2025.3☑️2024 - RobotStudio® User Group0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
