HELP, Where can I get the file missing for the back up?
Hello, as mentioned in the title, I've been facing difficulties in generating a station from the backup of an older robot. I've attempted to create it using the building tool, but I encountered a couple of issues. Initially, it prompted me for the Robot Ware version 5.12. I proceeded to download version 6 from the add-ins, but now it's requesting an SAC file. I've also tried the same with the STAND-ALONE CONTROLLER in add-ins, but I continue to encounter the same error message when attempting to create the station.
NOTE: THE POP UP SAYS `The media pool does not contain the additional Option: SAC, a system cannot be created from this back up`
NOTE 2: IT ASKS FOR THE SAC version 5.12.4003.04 I have not been able to find it online so far
  • You need the RobotWare 5.12.X installer. SAC is part of it.
    Contact your local (country) ABB Robotics Tech Support for the RW, and if necessary the SAC installer.
