Is it possible to change wobj0?
Hi all,
I'm doing some attempts on RobotStudio to understand better the coordinate systems hierarchy.
I moved the base frame at x = 1000 mm in the world coordinate system (and accordingly in RobotStudio I see that the robot is correctly moved with respect to the world).
Now i want wobj0 to coincide with the base frame, so I modified it in RAPID:
PERS wobjdata wobj0 := [FALSE, TRUE, "", [[1000, 0, 0],[1, 0, 0, 0]], [[0, 0, 0],[1, 0, 0, 0]]];
But it looks like this change is not affecting the system; still from the jog window on the virtual flex pendant and from the online value in RAPID I see that the current value for wobj0 is the default one (and so it coincides with the world coordinate system):
PERS wobjdata wobj0 := [FALSE, TRUE, "", [[1000, 0, 0],[1, 0, 0, 0]],[[0, 0, 0],[1, 0, 0, 0]]];
Is it possible to change wobj0 in someway?
Thank you
Thank you
So define wobj1:=[...,[[1000,0,0]...]; and use this ?
Notation: RootFrame -> Depends on root frame
RobotStudio Frame (RS-WCS) -> Task Frame/Controller World-> Base Frame- RS-WCS is only in RobotStudio
- Tasks are RS lingo and is the World Frame of the real-world controller.
- I believe that wobj0 references the World frame and not base. I would have guessed that other wObjs reference world and not wobj0 but you could make a quick test to confirm.
1 -
@XNOR indeed all work objects are referenced to the Task frame (in RS)/World frame (in reality). But wobj0 is a special kind of work object that you cannot move away from Task/World frame.
You are more correct than I was, when I said that wobj0 is a reference for all work objects, which is why I removed my post to avoid confusion.
Then, talking about a real case, it is only possible to move the base frame with respect to world, but not to move wobj0, which coincides with the world frame. Is this right?0
- 87 OmniCore
- 42 AppStudio
