(Robot Web Services) Set Robo Target Position does nothing
I might be misunderstanding the purpose of that request in which case I want to ask, how can I set the position and orientation of only the robot's tool via Robot Web Services? And do I need to do anything specific within the VirtualFlexPendant before I send the request? I want to set the XYZ and orientation of the tool and have the rest of the joints adjust to the new position as if I were performing a Linear Jog from RS.
To clarify, I'm just trying the request in Postman for now so I haven't modified it in any way. I'm just submitting the example curl request with different values. I'm also working with a VC and logging in as a default user.
Yep - I spent a lot of time getting to a 204 and it does nothing for me, either. I had assumed it would move the robot to the specified target...1
I am working on the same problem. I log in, request mastership for motion, set the tool for the mechunit, and set the position-target or joint-target. Nothing happens.
When doing this, I get the same logs in the events list of RS as when performing a goTo Location from inside the Wizard of my virtual Flex Pendant:
10289 Tool has been changed
10291 GoTo positionI would be happy to get any information about how to move the robot to a specific location using RWS.
Here is an example how you can move the robot to a specific location via RWS:
Request motion mastership:
curl --request POST \--url https://localhost/rw/mastership/motion/request \
--header 'Accept: application/json' \
--header 'Content-Type: application/x-www-form-urlencoded;v=2.0' \
Set jog-mode of your mechunit:
curl --request POST \--url https://localhost/rw/motionsystem/mechunits/ROB_1 \
--header 'Accept: application/xhtml+xml;v=2.0' \
--data jog-mode=GoToPos
Set position target:
--url https://localhost/rw/motionsystem/position-target \
--header 'accept: application/json' \
--data pos-x=530.0 \
--data pos-y=30.0 \
--data pos-z=600.0 . . . . . (all parameters)
Get change count from motionsystem:
curl --request GET \
--url https://localhost/rw/motionsystem/ \
--header 'accept: application/xhtml+xml;v=2.0' \
Start jogging (add current change count to parameters):
--url https://localhost/rw/motionsystem/jog \
--data axis1=200 \
--data axis2=200 \
--data axis3=200 \
--data axis4=200 \
--data axis5=200 \
--data axis6=200 \
--data ccount=13 \
--data inc-mode=Large
Reset jogging:
--data axis1=0 \
--data axis2=0 \
--data axis3=0 \
--data axis4=0 \
--data axis5=0 \
--data axis6=0 \
--data ccount=13 \
