RobotWare Add In, custom settings/config
Quint
Hi All,
I'm trying to develop a RobotWare Add In. Everything is going wel, but I would like to add custom configuration options to the controler -> configuration menu.
I know this is possible, because for example the Fronius Add In has this functionality:
However I'm not able to find any documentation on how to do this. Could someone help me with that?
I was able to unpack the Fronius the add in and was able to reverse engineer it a little bit, but having proper documentation would be great.
Thanks Denis, I am able to successfully create a package with the Add-In Tool, but unfortunately the documentation doesn't explain anything about these configuration settings
Do you want the same thing as this?
https://forums.robotstudio.com/discussion/13271/custom-system-parameter#latest
Yes that is exactly what I'm looking for!But forget my ignorance, I don't see where in the documentation this is explained?Would you be able to share your project where you created your own settings?0
