Calibration
How do one calibrate the robots? I've read the manuals but don't get it anyway. I'm running MultiMove with two IRB140 robots.
  • Hi,
    You can calibrate just one of two robots in a flexpendant you must go to the ABB menu then click in CALIBRATION and it will apear your two robots, select the robot that you want calibrate ROB_1 for example.
    I don't kown if hi response to your question!
    regards,
    Joao Fidalgo
