M2000 service port problem
I am trying to connect to the service port, I can successfully ping the controller from my laptop (Win10 enterprise), but when I try to connect with FileZilla, I get a message like could not parse path. Is there a setting somewhere that I might have overlooked? I have downloaded RobotStudio4, is it worth the hassle to dig up a XP machine and try?
Geir
What is it that you need to FTP to/from the controller? You could make a virtual machine with XP instead of dragging some old fossil computer out of the back of a closet.
Are you using a crossover cable? Have you set your computer's IP to the correct address and subnet?Lee Justice0 -
Straight patch cable, I suppose since I can ping the controller and FilZilla does connect that the ethernet bit is OK. I have the floppy to USB adapter, so it is rather easy to edit programs in Notepad, but I am a bit annoyed that I can't get the FTP to work. It's a school thing 😎
Did you log on using FZ?Lee Justice0
Yes it logged on, but gave the error message unable to parse path or something like it, I got the Norwegian version. So, is it a Win policy problem, firewall problem, FZ settings problem or something else?
I am not familiar with that error. What does FZ help say about it?Lee Justice0
There is a discussion here about a similar problem, but it seems that the FTP server is at fault https://forum.filezilla-project.org/viewtopic.php?t=36777 but people have used FZ with S4C+ before, have things changed in the mean time?
I have used it before, but it has been many years since.Lee Justice0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
