Help button "F1" shows wrong chapter
Hello,Works well on 2023.3...☑️2024 - RobotStudio® User Group0
Very strange. All of a sudden it works for me too. I also have 2023.3.-----------------
David
I got the same problem but on version 2023.4.1 .
When pressing F1 on "WaitTime" then "WaitGI" always pops up.
It's like they are all offset but its not consistent. sometimes 6 rows down and sometimes 7 rows down.
Starting from RobotStudio 2023.2 the RAPID editor tries to use the RAPID manual for the RobotWare version on the robot controller where the RAPID file is located.
If RobotStudio is unable to figure out the RobotWare version, such as when opening a local RAPID file from your computer, then there can unfortunately be a mix-up of the RAPID manual chapters if both RobotWare 6 and RobotWare 7 versions are installed on the computer.
Thanks for making us aware of this issue. The issue has now been forwarded to the correct team internally.
3 -
Ok!GöranZachrisson said:Starting from RobotStudio 2023.2 the RAPID editor tries to use the RAPID manual for the RobotWare version on the robot controller where the RAPID file is located.
I accidentally uppdated all the add-ins and "Robotware for omnicore" was one of them. So it could be that after the update the problem appeared.
Is there a way to fix it manually?
I tryed to remove Robotware 7 in the "Add-ins" tab, but no change.
Now it works as inteded.
Could be that when I opened up a singel mod file with "Right click mod file>open with> chose another application>robotstudio 2023".
