Do off delay
Goodmorning all,
Is there an instruction for an off delay of an output?
  • To turn on the output in 1 second write
    SetDO\SDelay:=1, doGrip_1_Close,1;
    To turn off the output in 1 second write
    SetDO\SDelay:=1, doGrip_1_Close,0;
    From the manual.
    [ \SDelay ]
    Signal Delay
    Data type: num
    Delays the change for the amount of time given in seconds (max. 2000s). Program execution continues directly with the next instruction. After the given time delay the signal is changed without the rest of the program execution being affected.
    If I helped, please press Vote Up  :smile:
  • Thanks Tompanhuhu, mist that completly in then manuals!
