Unable to restore the controller from backup (error code 80001)
I've tried to restore the controller from a previous backup(s) every time I get error 80001 "Stationname must match if interfaces are the same"
what is this?
  • lemster68
    lemster68 ✭✭✭
    Is that a real controller or a virtual controller in RS?
    Lee Justice
  • real controller
  • lemster68
    lemster68 ✭✭✭
    In that case I would check to see if the controller has run out of storage space, if possible.
    Lee Justice
  • I'm not sure storage space has got much to do with "Stationname must match if interfaces are the same" but there is loads of it
  • lemster68
    lemster68 ✭✭✭
    Yeah, I was overlooking that.  What could station name mean?  Do you have external axes in this setup?
    Lee Justice
  • wish I new, it's just a robot with a built in io module and a profinet connection to a plc. It's a bit of a fundamental flaw if you cant restore the backup that was made the day before!
  • lemster68
    lemster68 ✭✭✭
    Search the backup for Stationname.
    Lee Justice
  • I have the same problem, when trying to send IO changes to the robot from ioEngineering. i get the error: 80001:  Stationname must match if interfaces are the same
    I cant find station name anywhere
  • so i think the station name gets assigned to the robot by the profinet plc. In the end we gave up trying to used profinet safety signals and hard wired it.
