3DP Power Pac buggy with multiple robots
I created a virtual controller with three robots ( 4400, 4600, IRPB ) and tried to install 3DP V2 onto the system. It failed to install and put the appropriate modules in the RAPID structure.
When I do the same installation with only a single robot ( 4400 ) it functions correctly.
Is the inability to install 3DP powerpac in a multi-arm system a known bug?
Hi @cmaynard
Unfortunately 3DPP only supports one motion task: T_ROB1. So multimove systems are currently not supported.
