Could I declare my own variable???
ollitap
Hello,Time is not a valid data type.To declare your own type use ALIAS (to copy from other type) or RECORD to make a new structured data type.You can check valid data type in "RAPID Instructions, Functions and Data types" help.In your case, you should use clock data to use with ClkReset, ClkStart, ClkStop, and ClkRead.
Agreed and thank you0
- 365 IRC5
