Delete settings and data in "HOME" folder Robotstudio
Hello, I have a noob question.
I've been trying to delete some of these folders(See screenshot), but cant find a way.
"Rick click" won't give me that option.
There is a lot of scrap in our controller at the moment so i want to clean up a bit.
Screenshot: https://imgur.com/a/KNe83DF
Thanks for the help
Thanks for the help
Make a fresh backup of your system firstly. Then connect via the service port on RS, under controller option there is a File transfer option. Delete the files from there. Just check if these files are not in use on your current controller before assuming everything is fine.
Thanks!jmf said:Make a fresh backup of your system firstly. Then connect via the service port on RS, under controller option there is a File transfer option. Delete the files from there. Just check if these files are not in use on your current controller before assuming everything is fine.0
